Mk1 RHD Speedo Cable?
Tee3
Post by Tee3 »
Etka shows the Golf part as 200mm shorter, does anyone know if they can be rerouted on a fuel injected Mk1 to fit?
I've looked at having speedy cables make one, but they dont think they can re-use the gearbox end of mine and its not a part they have.
I can do it another way with a new mk2 cable and have the speedo end swapped for an early one, but if the Golf one will fit thats easier and probably cheaper
Tee3
Re: Mk1 RHD Speedo Cable?
Post by Tee3 »
Just for future reference... there doesnt seem to be an off the shelf Mk1 Speedo cable.
Speedycables can make one, but they cannot source the gearbox end.
So... I Supplied them with a GEMO Mk2 Scirocco cable and they shortened it and fitted a new speedo end.
Gemo made the cables for VW and you can buy a mk2 RHD cable from GSF.
So effectively an OEM quality cable, and the part that Speedycables modified looks factory.
I brought mine new from GSF about 6 years ago it is a GEMO cable, its good to know if it does break you have found a solution to the problem. Top work! :good:
very useful.
stickied.
chopperoli
Post by chopperoli »
Did you get it sorted? A bit late to reply but I have got a Mk1 GTI speedo cable, it has a Scirocco Mk1 RHD specific part number
Hi Oli, if this is spare I need to replace one from Ant's stash that enabled my 81 to hit the road this week.
Let me know?
cheers
pm'd too.
Resurrection - does anybody have the part number for a RHD Speedo cable to suit the Mk1 GTI?
And any other info re. length etc etc.
Post by mr.brown »
532957803C and 1820mm is what the parts diagram says.
