Hi Guys,
I'm in the process of converting my GT2 to an ABF and I'm in need of some bolt numbers if anyone can help...? I'm a bit stuck however, as I'm unable to see either engine!
I need part numbers for:
- the bolts that hold on the engine mount (drivers side) to the block, they should be 4x hex bolts
- the engine mount (drivers side) bolt
- the bolts that hold the gearbox to the block, poss one or two through the starter motor??
- bolts for the front and rear engine mounts
As I mentioned, I am unable to see either engine at the moment so if anyone is able to take pics of these ares that would be very much appreciated.
Many thanks in advance,
Andy
A few bolt numbers if you please
- Blueshark
Re: A few bolt numbers if you please
N 014 709 1 4x
N 010 472 11 1x
N 019 524 1 2x
N 902 992 01 1x
N 044 760 1
N 044 742 1 1x each
N 010 254 14 2x
rear engine mounts
Has no bolts just 3 M10 and 2 M12 nuts.
Posted this a good while ago, sorry for the slow reply. Thanks very much Joost!
Andy
Andy
- Blueshark
You are welcome, does it al fit and is it in place now?.andyneedham2 wrote:Posted this a good while ago, sorry for the slow reply. Thanks very much Joost!
Andy
Wow, been away from the forum for a while now. Things have slowed down on the car front recently, mainly due to having a house, weather and a garage that is too small meaning that I can't have all parts present. So I have to collate the parts and then get the engine dropped in all in 1 go!
Got a friend booked to do some welding and I'll be dropping the block on soon! I really must start a thread to make myself progress with the build!
Andy
Andy
