Starter moter bush thingy bob
Derbyboy
Post by Derbyboy »
Has any one changed one .i think mine needs changing as it seemed to need lots of power to turn over any advice welcomed ( sensible preferred)
Thanks in advance
Paul
aaron
Re: Starter moter bush thingy bob
Post by aaron »
just a thought but have you checked your earth connections, make sure there clean, making a good contact and no breaks etc, always worth checking before you pull the starter out.
Derbyboy
Post by Derbyboy »
aaron wrote:just a thought but have you checked your earth connections, make sure there clean, making a good contact and no breaks etc, always worth checking before you pull the starter out.
Yes checked the earth connection seemed good,
Thanks paul
how did you check it? get a multimeter on it and measure the voltage drop over the earth route from starter to battery. also worth checking the +ve cable for a voltage drop too. they do slowly degrade over time
Derbyboy
Post by Derbyboy »
Nate wrote:how did you check it? get a multimeter on it and measure the voltage drop over the earth route from starter to battery. also worth checking the +ve cable for a voltage drop too. they do slowly degrade over time
The A A man checked for any voltage drop from the battery to starter ( had flat battery ) if the car does not start first turn it will need jump starting even when battery fully charged ( battery checked by AA man) that's what made me think starter motor bush ?
Thanks Paul
you could try stripping it down, cleaning it all out with some degreaser or carb cleaner, greasing it up and re-assembling. they are reasonably straightforward to strip, and haynes usually explain them quite well
Derbyboy
Post by Derbyboy »
Will do when I get a day off work :yahoo:
Thanks Paul
