Pre-MOT check on the Scala today and found that the headlights don't come on. The sidelights work just fine so the problem appears to be the dip/main beam switch. With the switch in-situ the main beam won't stay on and the dip beam doesn't work. With the switch removed from the steering column and operated by hand (not the stalk) I can get the main beam to operate and stay on but when switched back to dip again nothing except sidelights.
Is the switch fixable or do I need to source a complete new unit (part number 331 953 519 B I think), if the latter where on earth do I get one from as the usual suspects don't seem to stock them?
Or, is the problem elsewhere and I'm just looking at what I think is the obvious source of the problem.
MOT isn't until Thursday so I have a few days in which to sort the problem out.
Andy
headlights not working
bensspares
Re: headlights not working
Its normally the switch that causes these symptoms.
Check that part number.
The switches I have are;
321 941 531 g
321 941 531 k
323 941 531 j
321 941 531 f
321 941 531 g
321 941 531 k
323 941 531 j
321 941 531 f
- AndyJ
From Vagcat
(6) 331953519B
switch for windshield wiper, wipers and washer and multi function indicatoroperation with memory button / F 53-F-000 001>>
(6) 331953519B
bensspares
I meant the headlight switch, its normally that..
Let me know if you need it
- AndyJ
Turned out to be both switches
However, got it sorted and the Scala now has another year's MOT
