mk1 golf coilovers
rocco robin
mk1 golf coilovers
Post by rocco robin »
will mk1 golf coilovers fit the rocco mk2
Re: mk1 golf coilovers
They will fit as they have the same suspention set up, I'm not sure about spring rate etc as I think the mk1 Golf weights less than a Mk2 scirocco, Im not expert on these things as i only run mine on the standard set up.
Someone else might post more info who have fitted coilovers to a Mk2
Dave_1990
Post by Dave_1990 »
im running mk1 golf gti koni 40mm springs and dampers on my 89 scala if that helps :good:
