I'm taking out my suspension struts, front and rear. The rear lower bolts came out fine, but the top nut holding the rubber mount it just wont come off! Normally these are easy! I've sheared of the flat bit at the top using not so glamorous mole grips. I just dunno what to do now.
What techniques do you guys use for getting these nuts off?
The fronts are the same, ive tried using the allen key thru a socket trick but its no good.
