Also, i thought once I had removed the house the rod the bearing pushes against would slide out, but mine didn't. Is that right?
Depends on how many ball bearings you found! According to BrokeVW, (http://www.brokevw.com) the thrust bearing has anything from 6 to 8.Ashrocco wrote:I knew my clutch bearing had failed, but should I be concerned with the ammount of crap I found in the housing??
