Would like to buy a oil temp gauge to fit in that hole next to the ashtray.
In the engine bay the there's a wire comes off the oil filter bracket. Is that where I'd have to attach the gauge to? And any ideas where I can get an original one from?
Thanks.
Oil temp gauge
Oil temp gauge
Scirocco Mk2 1989 scala injection (silver)RIP
Scirocco mk2 1988 scala carb (red) Alive and kicking.
mr.brown
Re: Oil temp gauge
The wire you're referring to is probably one of the oil pressure switches. If you look nearby you will most likely see a spare hole with a blanking plug in it. This is where you will have to fit an oil temp sender - a wire from this will then go the gauge (on VDO gauges it will be the G terminal). From the back of the fusebox you will need to find an ignition switched power supply and an earth. Simples.
Re: Oil temp gauge
moved here - as per this - http://www.sciroccoregisterforum.co.uk/ ... 3&start=15
Re: Oil temp gauge
Thanks! And sorry for not posting in correct place.
Rick
Rick
