Can you fit the electric window switches to the standard door cards where the window winder handle comes through?
It looks like the hole is roughly in the same place but obviously will need some cutting. Anyone confirm this before I start deconstruction?
Also is there anything else that is different on the cards and car with electric windows? like the rubbing strip along the top of the card as mine doesn't have anything which is allowing air and noise to come through
