door flare
Re: door flare
Door flare?
Re: door flare
The bump strips. They will come off with a little heat, not too much though as your will burn the paint!
Re: door flare
Yes mate.
Re: door flare
They come off easily enough, depending on how good the glue is. Mine came off with a blunt knife and a little persuasion. The real pig is getting the excess glue off after the strips are removed.
Re: door flare
White spirit is great for removing glue residue, good for getting the bumpers black again!
Re: door flare
I used panel wipe... much the same thing I guess!
Re: door flare
i haven't done them yet, but for glue residue ive just used brake cleaner. but then again i love brake cleaner.
With that and WD40 i don't think ive ever come stuck in a job
snathe
Re: door flare
What you need for removing the leftover glue and bits of trim tape is an eraser wheel. They are a toffee coloured rubber wheel that you put in your drill. They remove all traces of trim tape, glue, decals, vinyl, etc without damaging the paint. Using spirits is very risky, as if the car has been repainted using 1k paint (cellulose for eg) the spirits can attack the paint and cause you a right headache!
'91 Pearl Green GT2 16v... Breaking
'80 MK1 GLS project... Sold
