This time using a single blunt screwdriver we worked on the inside of the tailgate and just coaxed a small section of the seal out at a time. Last time around I tried to wedge several screwdrivers in at various intervals, but this time like I say we were working with just one.
And the secret here was to not to leave the screwdriver wedged in position, but instead to just use it to fold the seal back in on itself so that it sat snugly against the edge of the tailgate.
The tricky bit is to get that first piece tucked in, but once you have it started you just keep carefully inching your way around the frame. As you do this the seal itself will start to raise the glass slightly out of the frame on the other side. You can keep doing this all the way around or, like we did, just do up one side and along about ¾ of the top edge at which point you should be able to coax the screen out.
Hopefully, the photo below will be clear enough to let you see what I mean by tucking the seal in on itself …
And then in no time at the entire screen was out …
And just in case you thought it didn’t come out in one piece
Just remember the technique we employed here was all about letting the seal prise itself out.
A big thank you to Andy for suggesting this approach and doing most of the coaxing.
And that was that really for today apart from getting a loan of a couple of trolley jacks and an engine stand from a friendly garage. All set for tomorrow’s mini meet when ianaudia4, mazzellan and stu.gtx
