Keskin KT1 7.5X16 & 9X16
plastermaster
Hi guys,thinking of buying some Keskin KT1 rims, 7.5x16 et20 front & 9x16 et15 rear. Will these fit mk2 Storm without arch mods? (running standard suspension at moment).
Also what size tyres do i need? (would frefer a little strech).
Cheers Steve.
Cheers Steve.
1984 Cosmos Blue Storm
Old Mac Rocco
Re: Keskin KT1 7.5X16 & 9X16
Don't knpw if this will help you or not
http://www.carbibles.com/tyre_bible_pg4.html
There is a section "Match your Tyres to your Wheels" might be worth a look.
check Mr Funks 'The Bandit' or my own 'Scala' project threads - they're about the nearest size wise to your plans.
i run 195/40- 16 on my 7 x 16's on fairly low coilies - minimal rubbing on nsf at roundabouts.
rear arches will need work i'd suggest.
plastermaster
Thanks for the replies fellas,
GTXTRA how much did you lower Scala on coiles? Also are they 7inch rims all round & what et are they?
(Like the look of the Scala by the way) Cheers Steve.
cheers - they're 8 x 16 on the rear with 205/40 - 16 rubber.
i'd 'guess' she is about 50mm lower on the front, slightly higher on the back, rear arches rolled/sealed.
plastermaster
I had keskin kt5's on my scala lowered 45mm the fronts were fine and did not rub at all with 40 profile can't help you with rears as mine were 7.5's all round
plastermaster
Thanks daveyg,
do you know what offset youre 7.5s were, the ones im looking at are et20.
plastermaster
Right guys,im desperate to order these new rims but still not sure what offset to order.
My options are front 7.5x16 et20 or 7.5x16 et35 and rear 9x16 et15 or 9x16 et25 or 9x16 et30.
Is anybody running 9"s rear & 7.5"s front if so what et are yours?
PS my suspension & brakes are standard.
Cheers Steve.
Cheers Steve.
I am but can't for the life of me remember what the offset is. I've just got in and I'm freezing but I'll be out in the yard again tomorrow if you can wait?
plastermaster
plastermaster
Mr Funk, did you get chance to look at the et on you're rims?
- Jay4424
std et on the mk2 roccos are ET38 are they not?
'52 BSA A10
'37 72' wooden narrow boat
'03 Suzuki GSX1400
'52 BSA A10
'03 Suzuki GSX1400
plastermaster
They sure are sir but i want to know the best et for 9inch rears and 7.5 front?
Please anyone
Please anyone
Sorry I never got back to you, been a bit busy. Looked at the wheels but can't see the info, will have another look in the morning when I don't feel quite so arse.
Got a feeling theyre something odd like et10 or 15
