FUN AND GAMES!
(without the fun)
I was loosing water from the side of the block from the headgasket. So headgasket change was on. This was back in June time.
That went well.....
The next day I ran the car and all the oil got pumped into the water system! Having only changed the water cooled oil cooler last year, I thoughtit could not possibly be the cooler. After taking the head off another two times thinking i'd done it wrong (even getting a friend in to help on the last time tomake sure I was not doing something daft) it did it again. I then was told by new workmate who knows more then most about these things to by-pass ther water cooed oil cooler. And whatdo you know, oil came pumping out of the water side!!!
After that the fuel pump in the fuel tank gave up,
Most headlight plastic nuts broke as I was driving home at night. the headlight beams doing a can-can on the road ahead!
...and at the moment I keep having to replace water hoses and the fan didn't work the other day (thats new too) and water is dissapearing out of somewhere, I suspect my (also newish) radiator!
.....more to come I feel.
