Accelerator Cable Replace
jonkennedy
how on earth do u get the accelerator cable through the housing / hole in the car body ?
do i have to cut the bush ?
i just cant seem to be able to push it through..
bensspares
Re: Accelerator Cable Replace
try harder lol....it will but requires some effort.
jonkennedy
pushing from inside car to out applying pressure to the pink / white plastic *nipple *?bensspares wrote:try harder lol....it will but requires some effort.
bensspares
best to pull from engine side...its a tight fit....persistance pays...
jonkennedy
DT1
Put some lubricant around where the grommet and cable meet then insert something like a thin screwdriver between the cable and grommet and roll it around the cable to break the seal and take some lubricant into the join.
Then push the grommet from the inside of the car out along the cable, long flat screwdriver is good for this.
jonkennedy
DT1
Shouldn't do but I can't guarantee.
If it's the original grommet you might want to replace it anyway.
jonkennedy
andyneedham2
Mines a carb car so one end it caught in a nipple by the carb. I took the gromet out of the bulkhead I think, put it over the cable and then got the gromet back in. Failing that would you be able to open the gromet up with some pinch nose pliers?
Andy
Andy
jonkennedy
