Uprated headlight loom
I've been looking at getting an uprated (relayed) headlight loom, and on eBay the price for these has gone up to £35 recently.
Looking at the pictures of these, it looks like they're a pretty straightforward setup, and I imagine it'd be easy enough to make this oneself.
So rather than pay £35 for someone else to make it up from parts that probably cost less than a tenner, I was wondering - is there anyone who's bought one of these (or has made one in the past) who'd be willing to post up some instructions on components to buy, how to assemble and how to fit?
- Jay4424
Re: Uprated headlight loom
dead easy!
you need:
a drum of wire, (flexi extention cord will do!)
crimps (blue) or solder and heat shrink depending on your prefererences,
a box to put it in (splah proof if you want),
2/3 of the following:
inline fuses (15A)
relays (12VDC coil, 15/20A capacity),
i can work it out for you, but it'd be quicker doign it there your self on the! find out hte wiring colours for the dip. main and earth.
which ever side you stick the relays in the thire box, use that sides orinigin al wiring for hte control (feed to hte relays). the other, cut and insulate.
the rest is jsut a big wiring job, replacign whats there, connecting up etc... again I can do a wiring diagram if you need it.
Jason.gallop@eon-uk.com
if you want one (a wirign diagram that is) and I'll try and make one up this week.
Jay.
you need:
inline fuses (15A)
Jay.
'52 BSA A10
'37 72' wooden narrow boat
'03 Suzuki GSX1400
'52 BSA A10
'03 Suzuki GSX1400
Nice one guys, just what I need! Off to my local Maplins on the weekend methinks :)
- Jay4424
will it really be cheeper though?
'52 BSA A10
'03 Suzuki GSX1400
'52 BSA A10
'03 Suzuki GSX1400
I guess that's what I'll find out next. I'll let you know!
Hmm, well it seems that buying the gear from Maplins will cost about £30, and that's not including heatshrink or connectors. So I guess it's just as expensive as buying the kit from eBay and also involves more hassle! Never mind - was worth a check :)
- Jay4424
Foonzooroo had the kit off Ebay, but found that he had to extend the wirign alittle to make it reach! ...still less work/money than makign the entire system your self!
'52 BSA A10
'03 Suzuki GSX1400
'52 BSA A10
'03 Suzuki GSX1400
- fonzooorooo
true - ish... yes, I got the ebay kit, fitted it, and it functions beautifully. Snag is the wires between the relays and battery aren't long enough, meaning that you can't really install it anywhere! I cable tied the relays to a couple of wires as a stop-gap... it's been like that for the best part of a year now! It'd be much nicer soldered/heatshrunk in place, rather than crimped as supplied.... Worth doing it nicely.
What I do:
- Junglist
i'll make you one for £20 posted. I can do it today and it'll be with you tuesday.
Now that's tempting! I'll check on funds and get back to you... Might be midweek if that's ok?
- Junglist
No rush but I can't do anything on thursdays and fridays so let me know before then or it'll be the following week. Up to you - I'm easy. I made one for Ash Lough off here. Ask him what he thought of it if you want a review.
No rush - it's something I've been meaning to do for a while but never got round to! I'll give you a shout in the week :)
