how much boost?
richlyons
how much boost?
Post by richlyons »
how much boost can a standard 1.8 8v inj run?
ive got a spare block kicking about and a turbo set up that came off a 1.9 tdi the manifolds are the same i just wonderd if i can mate the two together?
1988 helios blue scala, weber carb, gti cam,
1989 red gt2 (daily)
Brunty
Re: how much boost?
Post by Brunty »
It's said that a standard n/a engine will take 6psi. But, it needs to be solid in the first place or you'll just blow past piston rings and valve seals otherwise. You'll need a standard cam too as I believe forced induction doesn't like much overlap.
You planning on running it through the KJet? I'd increase fuelling somehow and fit a wideband lambda to monitor the afr.
Brunty
richlyons
Re: how much boost?
Post by richlyons »
im just in the thiking stages atm, but it would be kjet
i would only have it in for about a month if that while i rebuilt the engine thats in the car
