Steering wheel boss/hub adapter
Akinesis
Post by Akinesis »
Hi all,
Does the Scirocco have its own steering boss requirement or is it the same as the Mk1 Golf?
Thanks in advance :cool:
GTII Track Project... now a different animal for 2009
Re: Steering wheel boss/hub adapter
Post by Ryan »
Earlier cars are the same as mk1 golf, later ones as per mk2 golf* I forget what the changeover year is '87/'88/'89?
*the spline on the later cars can be removed to allow fitment of the mk1 golf boss, but this can be tricky if you're not built like Arnie.
Akinesis
Post by Akinesis »
My 'Rocco is F-reg (88?). Hmmm, right on the cross-over year by the looks of it :dash:
this should help
http://www.venommotorsport.com/manufact ... l=Scirocco
call them - you should be able to verify via quoting your chassis number.
Risocco
Post by Risocco »
I was under the impression if your factory wheel is the "4 button horn" type, then your car is small spline, if the later, chunkier single horn wheel is fitted its larger spline? :dunno:
Please anybody feel free to correct me if I'm wrong :cool:
Alex
Slugga
Post by Slugga »
Akinesis wrote:My 'Rocco is F-reg (88?). Hmmm, right on the cross-over year by the looks of it :dash:
Take your steering wheel off and measure the diameter of the spline and post it in here. I will compare it to mine (steering wheel is off at the moment so easy to do) and then you can be 100% sure which you have :)
Akinesis
Post by Akinesis »
Ok, I'm over at the garage all day tomorrow, so I will have a look and post it up tomorrow night. Cheers for that :ok:
PeteGLi
Post by PeteGLi »
From August 1988 a short multi-splined adapter sleeve (Part Number 191 419 514A) was fitted onto the steering column splines.
From January 1989 the short multi-splined adapter sleeve was gradually replaced by a long multi-splined adapter sleeve (Part Number 191 419 514). In conjunction with the long multi-splined adapter sleeve, the spacer sleeve used with the short multi-splined adapter sleeve was replaced by a spring.
Akinesis
Post by Akinesis »
Slugga, the spline measured to be roughly 15mm in diameter. What do you make of that?
Slugga
Post by Slugga »
100% you have the early, smaller type. :)
Akinesis
Post by Akinesis »
So Mk1 Golf bosses are the kiddie my my 'Rocco? Many thanks, Slugga - you've been a great help :buddy: Nearlly bought a Mk2 boss, aswell :blush: To answer your question, Risocco, I have the larger horn type wheel, but the smaller Mk1 spline - so your theory isn't quite right :nerner: Cheers for all you help, guys :cool:
Slugga
Post by Slugga »
No sweat. I'm sure the diameters are something like 15/16mm for the earlies and 25mm ish for the late ones.
millsy20
Post by millsy20 »
Yep definatly the smaller spline. Ive got an early golf Mk2 with the four button steering wheel and that it the small spline and a 91 Scirocco with the larger spline so I measured them both and its around 15mm for the smaller spline.
1991 Red Scirocco GT2-Soon to be GT2 16v
2010 MK3 Scirocco GT TDi 140 for daily duties
