Does the Scirocco have its own steering boss requirement or is it the same as the Mk1 Golf?
Thanks in advance
Take your steering wheel off and measure the diameter of the spline and post it in here. I will compare it to mine (steering wheel is off at the moment so easy to do) and then you can be 100% sure which you have :)Akinesis wrote:My 'Rocco is F-reg (88?). Hmmm, right on the cross-over year by the looks of it
Yep definatly the smaller spline. Ive got an early golf Mk2 with the four button steering wheel and that it the small spline and a 91 Scirocco with the larger spline so I measured them both and its around 15mm for the smaller spline.Slugga, the spline measured to be roughly 15mm in diameter. What do you make of that?
