hello
Scala 1.8i 1990
jumps out of 5th gear at 80 and whines...all the others are fine.
what would be causing that..collapsed bearing ?
whineing 5th
kevtherev
whineing 5th
Scala 1.8i 1990
driven with pride
driven with pride
kevtherev
Re: whineing 5th
OK thanks
is it worth replacing the worn parts or just get a used box..
if so which boxes are straight swaps
1.8i scala
1.8i scala
Scala 1.8i 1990
driven with pride
driven with pride
Re: whineing 5th
Id go for another box, pref one with less miles.
Have a look at the gearbox code, stamped underneth gearbox where it meets the engine. There is a smooth bit of alloy there with the code.
Then use the "gearbox code's" found at the top of this page to find a match..
