Brake drum help
Jack92
Site Admin
Brake drum help
Post by Jack92 »
Hey guys,
Does anyone know what drums I require for my rocco. It’s a 1992 Kjet scala.
I’ve been looking on heritage and euros but still unsure on the size.
They both seem to say 180 but I’m sure the one on the Car is larger?
Also after the rear bearings for it but can only seem to find an option on Euro’s? Not vwh which seems odd
Any advise would be amazing as the car was meant to be having an mot tomorrow and this is yet another delay.
Jack
South East
VW Scirocco Scala MK2 1.8 Inj
Jaguar F-Type
Jack92
Site Admin
Re: Brake drum help
Post by Jack92 »
Ok so I’ve been out and had another look and took some measurements as best I could...
The depth size I keep thinking is 30mm but these seem to be 40 :-/
Really confused
Jack
South East
Jaguar F-Type
Re: Brake drum help
Is it not theses that fit?
You will need 2 and it’s best to fit new shoes when fitting new drums.
https://www.eurocarparts.com/handbrake-drum
Rear wheel bearing kits.
https://www.eurocarparts.com/ecp/c/Volk ... b83&000370
Jack92
Site Admin
Re: Brake drum help
Post by Jack92 »
mark1gls wrote:Is it not theses that fit?
Yeah there the ones I’ve found, but I don’t trust this car lol having looked at the drums they seem slightly bigger...
I’m planning on going to see Jim tomorrow as he things he has some so I’ll take a look.
On a different note why are euros like £44 when VW heritage are £18 lol
Now I feel like if I go to heritage they won’t be very good quality but then again when is euros ever haha
Jack
South East
Jaguar F-Type
Re: Brake drum help
Not 100% sure if they do fit as my cars a 1988, yours is the end of production so VW could of stuck on better equipment etc?
Pagid a good make.
£30 here and an extra 12% off with discount.
https://www.carparts4less.co.uk/cp4l/c/ ... f8b&000399
Oooh, just looked at your picture again and your drums look like Mk2 golf drums??
VW heritage listed these when I searched a Scirocco????
https://www.vwheritage.com/1h0501615a-b ... -golf-1989
Re: Brake drum help
It may be different wheel bearings as well?
Jack92
Site Admin
Re: Brake drum help
Post by Jack92 »
Hmm I haven’t a clue lol...
Joost told me to take a look for a part number on the drum so I’ll do that tomorrow and if need to I’ll strip one down to be able to get proper measurements...
why is this car always a pain in the arse lol
Sent from my iPad using Tapatalk
Jack
South East
Jaguar F-Type
Jack92
Site Admin
Re: Brake drum help
Post by Jack92 »
So,
I’ve stripped the hub down and found the part number which is 171501615B
I’ve phoned VW Heritage and they told me it’s actually off a South African golf... why South African I have no idea lol
Looking up the drum it’s the same diameter but the inner height it’s 38.5mm
Luke at VWH seems to think I should just be able to put standard ones back on.. any ideas?
Jack
South East
Jaguar F-Type
Jack92
Site Admin
Re: Brake drum help
Post by Jack92 »
So after another long chat with vwh we have come to the conclusion that it should work..
So I’ve decided to do a full Rehaul of the rear breaks with new back plates all the way forward. Fingers crossed they all fit easily lol [emoji23]
Thanks for your help again mark
Jack
South East
Jaguar F-Type
Re: Brake drum help
to be honest the only thing that changes in the drums is the width of the drum only with shoes so if you buy a matching pair of drums and shoes they should fit straight on.
the only different ones ive seen in diameter was the mk3 golf estate that had 200mm drums instead of 180mm so unless you've had a very unusual modification you should be OK with standard drums and shoes off heritage
Jack92
Site Admin
Re: Brake drum help
Post by Jack92 »
Thanks man eventually found the right bits after all sorts of parts being sent wrong lol
Jack
South East
Jaguar F-Type
Jack92
Site Admin
Re: Brake drum help
Post by Jack92 »
Any tips on rebuilding the shoes? What order with the springs etc as I absolutely hate shoes lol
Jack
South East
Jaguar F-Type
Re: Brake drum help
put all the springs on the shoes and then put onto the backing plate, you wont be able to get one side on at the bottom due to springs pulling them together.
get some pliers on the metal edge of that shoe and pull against the spring untill you can get it onto the backing plate.
then put the locating springs through into the backing plate.
ive found this is the easiest way.
