Inner light fitting
Inner light fitting
Hi all, I'm needing advice as how to fit the inner lights onto the front light brackets. @Blueshark suggested m6 bolts with locking nuts but the holes seem too large and it is difficult to stop them wobbling. Is there specific way to fit them this method or are there any other ways to fit them?
Any help would be greatly appreciated, the car had been converted to the 2 headlight setup some point before I got the car lol
Thanks in advance!
Chris
Thanks in advance!
Chris
1992 pearl green 1.8 GT2 daily
1983 Mars red 1.8 GTI project
Re: Inner light fitting
youre gonna need some of these
https://www.vwheritage.com/533941141-he ... genuine-vw
Cheers! Would I need 4 or just the top 2?
- Blueshark
None, because they are for the outer lights and not the inner ones, otherwise I could have sent them with the lamps.crimmer96 wrote:Cheers! Would I need 4 or just the top 2?
Joost
Blueshark wrote:None, because they are for the outer lights and not the inner ones, otherwise I could have sent them with the lamps.crimmer96 wrote:Cheers! Would I need 4 or just the top 2?
Joost
Not a prob Joost!
- Blueshark
Use a bolt long enough.
you have to make sort of a stack: bolt, washer, lamp, washer, nut, nut, washer, lampframe, washer, nut.
Lock the lamp between the bolt, washer, washer, nut and tighten by hand, do this for 3 holes in the lamp.
Then put the next nut and washer on 3x, place through headlamp frame, place washer and nut, with these you adjust the depth of the lamp in the car.
Tigthen all the nuts and the lamps are in place.
Joost
Joost
I'm in the process of removing some surface rust I've found behind the grill and on the edges of the crumple zone but once that's dealt with I'll attempt fitting them and let you know how it goes!
Lights fitted and all secure. Thanks for the guide Joost! It was a bit fiddly trying to lock them in place without removing the lamp frame but there locked on and easily adjustable this way.
