Steering rack boot.
steviet_1988
Steering rack boot.
Post by steviet_1988 »
Hi
Does anyone know where I can get the rubber boot thats on the steering rack behind the engine.
There ain't any scirocco's in breakers near me.
sorry I don't know how to upload pictures.
Thanks,
stevie
86 monza blue gtx, currently in mid restoration.
Re: Steering rack boot.
Its called the UJ boot, they get cooked by the exhaust and go britle and break up. They are not an MOT fail, mine was in bits for 10 years before I changed mine as the steering rack gave up so had to fit a new rack as I expect dirt and grit got into it where the boot should of been.
Try searching ebay or VW heritage seem to sell them but I'm not 100% sure which ones fit a Mk2 Scirocco.
Found this one but might be worth a phone call as I thought the Mk2 Scirocco one is a slighly different shape.
http://www.vwheritage.com/vw_spares_Boo ... tartPage=1
Blueshark
Post by Blueshark »
With or without power steering?.
Is a difference for sure.
Joost
I would guess its without power steering as I've never seen a mk2 in this country with power steering.
Blueshark
Post by Blueshark »
mark1gls wrote:I would guess its without power steering as I've never seen a mk2 in this country with power steering.
Are you serious?.
Joost
Yeah I'm serious ..... I think its just a myth that VW ever made a British registered Scirocco with power steering. :-D
Has any one on here got power steering, go on put your hand up!
mark1gls wrote:Yeah I'm serious ..... I think its just a myth that VW ever made a British registered Scirocco with power steering. :-D
Sean has power steering on his 16v.
marcus
Post by marcus »
Didn't know it was an option, wish I had it, despite the low weight (by modern standards), parking is a nightmare.
1985 GTL 1.8
marcus
Post by marcus »
Maybe power steering was only an option on left-hand drive models? ETKA only shows a power steering box for LHD models, whereas it shows manual boxes for both LHD and RHD.
1985 GTL 1.8
steviet_1988
Thanks guys. There is a few on ebay for 30 odd quid. It's just it will be easier to do it while the engine is out the car.
sorry to go slightly off topic, but the citigolf was available in rhd with pas... only a thought
steviet_1988
I eventually found out how to post pics. Here's how bad mine's is.
fonzooorooo
Post by fonzooorooo »
^ that looks pretty normal(!)
As above, I think mk1 golf are the same. Crazy Quiff do (or did) sell them too. £30 ish is the going rate.
Power steering is likely to be the same diameter, but shorter. (the turret on the rack is taller on PAS)
dubster
Post by dubster »
I have a mk2 scirocco registered 8th MAY 1989 fitted with power steering,reservoir feed (its R/H drive) bought with it leaking (from the boots) and about to get it done,I will tell you what i find.......
Whatever that is,myth or no! :shock:
dubster wrote:I have a mk2 scirocco registered 8th MAY 1989 fitted with power steering,reservoir feed (its R/H drive) bought with it leaking (from the boots) and about to get it done,I will tell you what i find.......
Not many cars about with power steering, is it a VW steering rack or an aftermarket type?
