Upgraded Throttle Body.
I wonder if anybody can help me off here we won't to buy an upgraded Throttle Body.As the inlet has to made bigger so you get more throttle reponse we all ready have the 16v fuel reglator which is part of the kit.
This is a popular upgrade for a DX Engine.
Will any of these fit please here ===
http://www.ebay.co.uk/itm/151667339066? ... EBIDX%3AIT
http://www.ebay.co.uk/itm/THROTTLE-BODY ... 2018269361
http://www.ebay.co.uk/itm/321804891508? ... EBIDX%3AIT
http://www.ebay.co.uk/itm/Audi-A8-4D2-4 ... 1804891508
http://www.ebay.co.uk/itm/262392092218? ... EBIDX%3AIT
http://www.ebay.co.uk/itm/Audi-80-Coupe ... 2392092218
http://www.ebay.co.uk/itm/392123-Butter ... 1336305841
http://www.ebay.co.uk/itm/Audi-80-B4-91 ... 1980166149
http://www.ebay.co.uk/itm/VW-MK1-GOLF-S ... SwS7hXAUNx
http://www.ebay.co.uk/itm/AUDI-2L-8V-AB ... Swa-dWrkZz
I know you have to modify these more like this ===
http://www.scirocco.org/tech/mk2/5000tb/5000tb.html#fox
http://www.scientificrabbit.com/node/24
steve bain
Re: Upgraded Throttle Body.
from memory ( 10 years) when i did this it was like the third one down. it was off an audi. you need to make sure it has the pipe on it as i bought one which didnt off a 16v i think. the third one down has the pipe shown. hopefully somone who knows will come along soon!
steve bain
actually it doesnt look quite right now i look at it again. if i remember next time i am at my car i will take a picture for you.
steve bain wrote:actually it doesnt look quite right now i look at it again. if i remember next time i am at my car i will take a picture for you.
Hello Steve great I would more then appreciate if you could please and thanks so much for your help.
- dingorocco
This TB is the closest to what your looking for. You can strip the linkage from the original TB and refit to the Audi item.
If it aint a MK 1 then it must be a donor
Brownrocc resto thread... http://forums.vwvortex.com/zerothread?id=3070996
Thank you very much does it need or is there anything missing like part from the smaller throttle body circle end out of the side of this Throttle Body like a brass part or a tube or does our mechanics take it off the throttle body which is on Sally ?dingorocco wrote:This TB is the closest to what your looking for. You can strip the linkage from the original TB and refit to the Audi item.
- dingorocco
If your running the standard distributor then it will need the vacuum advance port near the idle adjustment screw. When it stops raining here I will try get you a pic ( and part number ) of some of the bodies I have...
Ok many thanks that would be great.dingorocco wrote:If your running the standard distributor then it will need the vacuum advance port near the idle adjustment screw. When it stops raining here I will try get you a pic ( and part number ) of some of the bodies I have...
No I'am running the standard distributor so we will need the vacuum advance port near the idle adjustment screw.dingorocco wrote:If your running the standard distributor then it will need the vacuum advance port near the idle adjustment screw. When it stops raining here I will try get you a pic ( and part number ) of some of the bodies I have...
Think i used an Audi 80 5 cylinder one many year's back. The inlet needs to be filed to suit throttle body. Some 16v throttle bodys do have the vacume pipe on the rear again there a audi item, early type 90s
monzajake wrote:Think i used an Audi 80 5 cylinder one many year's back. The inlet needs to be filed to suit throttle body. Some 16v throttle bodys do have the vacume pipe on the rear again there a audi item, early type 90s
This the throttle body I'am looking to buy http://www.ebay.co.uk/itm/262392092218? ... Tags=bu=bu I have tried to share the info with the seller as I would like to be 100 pecent sure that it is going to fit before I buy after some adjutments are made of course.I have not herd back from the seller saying that they sale a lot of these since I sent the ebay shop this link http://www.scirocco.org/tech/mk2/5000tb/5000tb.html#fox
I've not done this mod or up on throttle bodies but does the number on the flap mean the size?
As the one in the link above has the same No.14 on the flap and looks the same size as my standard DX engine throttle?
My throttle body after a good clean.
I have now brought this one http://www.ebay.co.uk/itm/262392092218? ... EBIDX%3AIT
The number on the flaps (butterflies) is the bore of the throttle body.
I assume the numbers on this on are greater than the standard one on your DX ?
when you fit it to the inlet open up the butterflies and your see a ridge around the bore holes , as manifold is to small. This needs to be flied out.
- dingorocco
Managed to wade thru the shed junk....
Small vac port for running a vaccy advance dizzy..
Ports left undrilled, some of the other bodies had a breather port about 14 mm drilled. Some are threaded and I just screw in a sealing plug ( tapered thread)
Unsure if there is any coding to these numbers...
Original bores are 35/44 larger body goes to 35/52. Velocity tuning in the states modded bodies to 56 mm but pretty sure that business is now gone.
You likely will need to change some of the linkage for the throttle cable and can dump the switches if not needed.
Other bit of the mod is to locate an adapter or have the flange on the manifold welded so there is a bit of meat between the bigger bore and edge of manifold and the bypass port for the idle adjustment, they both run with very little sealing area to the outside of the manifold ( potential air leak later down the track ) Have to take a snap of the modded manifold on Valeries cabrio..
