Replacement carb flange
bengould
Re: Replacement carb flange
Post by bengould »
james butler wrote: Is there any way to retrieve old photos like that because I don't have them any more and were pre photo bucket days?
I don't think so. I'm not on the administration team for the forum but I would guess once it's gone it's gone.
Ben.
jakeb
Post by jakeb »
drawing edited slightly.
please note if you print this windows will re-scale it so the dimensions will be off.
out of interest because the transfer of heat from the manifold would it be possible to get these made from some kind of thermoplastic?
or even get some 3d printed?
james butler wrote:out of interest because the transfer of heat from the manifold would it be possible to get these made from some kind of thermoplastic?
Or how about a sort of rubber ?? Oh that's back to square one....... :hehe:
Joking aside, great idea for a common problem made worse by a webber carb bolted on to it.
Would be good to see how costing etc would be and maybe a few made as I may need one in the future.
jakeb
Post by jakeb »
Old Mac Rocco
Post by Old Mac Rocco »
http://www.ebay.co.uk/ulk/itm/261366810639
from item listing
" **THIS IS NOT SUITABLE FOR USE WITH PETROL, FUEL OILS (eg. DIESEL OR HEATING OILS), OR BRAKE FLUID** "
jakeb
Post by jakeb »
always read the not so small print Jake...
I'm pretty sure there's a Bakelite spacer that you can buy to help stop heat transfer.
The webers are also fitted to land rovers and they don't have the rubber carb flange so had a baker lite spacer to prevent heat transfer. If I remember correctly that is!
jakeb
Post by jakeb »
Something like this James?
http://www.ebay.co.uk/ulk/itm/191712174130
But in between the carb and manifold.
yeah your on the right track but need to go between the carb and the manifold instead of the manifold to the head.
ahh that link jakeb led me to this
http://www.ebay.co.uk/itm/WEBER-38-DGAS ... SwFnFWB7GX
this is what i was after
this guy seems to be doing 32/34 dmtl carbs for £197 too
jakeb
Post by jakeb »
James your link led me to this, dmtl version (y)
https://www.ebay.co.uk/ulk/itm/361021219915
Just in time for payday too.
after another failed rubber carb flange incident ive started making another alloy flange replacement part for a friend.
we really need someone to cnc some of these. maybe trimsport would like to have a go?
[=http://s1382.photobucket.com/user/james ... 6.jpg.html]Image[/URL]
[=http://s1382.photobucket.com/user/james ... b.jpg.html]Image[/URL]
[=http://s1382.photobucket.com/user/james ... e.jpg.html]Image[/URL]
steve bain
Post by steve bain »
Look at website lasermaster. They could laser cut the basic shape and you drill the holes. I bought 4no. 145dia discs in 5mm thick and it was £30 Inc delivery. Cheap as chips.
My build thread:
viewtopic.php?f=19&t=14083
