Got myself a 4 button Scirocco steering wheel, just found out it is a small spline and the shaft appears to have a big spline adaptor.
Tried various 2 legged pullers and got now where, not shifted at all.
Does anyone have a 3 legged puller I could borrow (North West) or what have you used to remove it before, any ideas ???
Mark
Removing steering wheel spline adaptor
Mark
Alpine White
VW Scirocco GT2 (1991)
Membership Number 1296
Alpine White
Re: Removing steering wheel spline adaptor
Here you go Mark - http://forums.vwvortex.com/showthread.php?2059093
- bengould
You can do it with a grinder/dremel if your careful and don't want to keep the adapter.
Don't grind all the way through, leave it as close as you can and split it with a chisel.
Ben.
Ben.
Finally got it sorted, what a bast*$d of a job. would not volunteer to do it again. Used bearing puller, 2 legged puller, heat and 18st of brute force
Mark
Alpine White
Alpine White
