Front valence
Front valence
Ok want to take the front valence off and sand down and paint the front panel,how does it come off and do you have to take off the kit from the wings ?
Re: Front valence
from memory, just pop the screw covers off and it comes off quite easy. you may find the heads are rotted so you cant grip them. to sort this, i have been known to just prise the plastic off, then use big penny washers when refitting [/redneck]
Re: Front valence
Very simple, 2 big plastic caps, ping them off to reveal the screws, remove them, mine were okay to come out with abit of wd-40, then underneath there is 6 (from memory) screws along the bottom, take all them out and it will come off in your hands, wings don't need to come off, I had the bumper off when I took it of / back on but I don't think it will be in the way, only 4 bolts if it is. You might need vies grips to hole the white plastic square things in place to remove some of the screws as afew of mine were just spinning with the screw :)
