there used to be a sticky topic for this on the old forum, where is it now?
cheers, Jay.
?getting power from your fuse box?
- Jay4424
'52 BSA A10
'37 72' wooden narrow boat
'03 Suzuki GSX1400
'52 BSA A10
'03 Suzuki GSX1400
Re: ?getting power from your fuse box?
recent experience shows there are two connections that are cable size 5.0 and they connect to the two large pins on block P on the back of the fuse box.
One runs to the battery and the other runs to the ignition somewhere behind the dash i believe.
http://www.angrymods.com/projects/scirocco/FUSEBOX.jpg
here is a link to all the pins for the fuse box, i found this very handy.
http://www.edition38.com/forums/index.p ... hl=fusebox
Rubjonny is to me an expert with bags of experience so I take pretty much what he says as gospel
most will be relevant if your running inj
insanecreations.net
insanecreations.net
Found this very handy to print out and keep lying about
http://www.a2resource.com/electrical/CE1.html
has helped me out on a few occasions!!
VW Scirocco 16V GTX, Kamei X1 and a half
- Jay4424
cheers guys, but still there was a topic on the old forum, wheres it gone?
....ok what i attually want to know, is which pin is it, or which of many, go live when the ignition is on? (output of relay X?)
cheers, Jay.
cheers, Jay.
'52 BSA A10
'03 Suzuki GSX1400
'52 BSA A10
'03 Suzuki GSX1400
the faq is your friend - see top of page on all technical sections pages.Jay4424 wrote:cheers guys, but still there was a topic on the old forum, wheres it gone?
cheers, Jay.
http://sciroccoregisterforum.co.uk/faq/ ... 12/test-2/
Dude, all German cars have the following wiring colours:
RED: Battery +ve
BLACK: Ignition
BROWN: Earth
There are pins on the battery input side that you can just connect a spade terminal to and get +ve. IIRC its on the left side at the back, as you're looking at the front of the fusebox
There are also pins on the ignition input side, right hand side.
Hope this helps.
RED: Battery +ve
BLACK: Ignition
BROWN: Earth
Hope this helps.
Neil Baker on old website.
1985 Mk2 Flash Silver GTX - Now sold to Millsy20
