?getting power from your fuse box?
Jay4424
Post by Jay4424 »
there used to be a sticky topic for this on the old forum, where is it now?
cheers, Jay.
'52 BSA A10
'37 72' wooden narrow boat
'03 Suzuki GSX1400
Rusty dan
Re: ?getting power from your fuse box?
Post by Rusty dan »
recent experience shows there are two connections that are cable size 5.0 and they connect to the two large pins on block P on the back of the fuse box.
One runs to the battery and the other runs to the ignition somewhere behind the dash i believe.
http://www.angrymods.com/projects/scirocco/FUSEBOX.jpg
here is a link to all the pins for the fuse box, i found this very handy.
http://www.edition38.com/forums/index.p ... hl=fusebox
Rubjonny is to me an expert with bags of experience so I take pretty much what he says as gospel :buddy:
most will be relevant if your running inj
insanecreations.net
Birdy
Post by Birdy »
Found this very handy to print out and keep lying about
http://www.a2resource.com/electrical/CE1.html
has helped me out on a few occasions!!
Jay4424
Post by Jay4424 »
cheers guys, but still there was a topic on the old forum, wheres it gone?
....ok what i attually want to know, is which pin is it, or which of many, go live when the ignition is on? (output of relay X?)
cheers, Jay.
'52 BSA A10
'03 Suzuki GSX1400
Jay4424 wrote:cheers guys, but still there was a topic on the old forum, wheres it gone?
cheers, Jay.
the faq is your friend - see top of page on all technical sections pages.
http://sciroccoregisterforum.co.uk/faq/ ... 12/test-2/
kariba
Post by kariba »
Dude, all German cars have the following wiring colours:
RED: Battery +ve
BLACK: Ignition
BROWN: Earth
There are pins on the battery input side that you can just connect a spade terminal to and get +ve. IIRC its on the left side at the back, as you're looking at the front of the fusebox
There are also pins on the ignition input side, right hand side.
Hope this helps.
Neil Baker on old website.
1985 Mk2 Flash Silver GTX - Now sold to Millsy20
