Lower Strut Brace
crashbanggg
Lower Strut Brace
Post by crashbanggg »
Am I right in thinking this strut brace will fit my Mk2?: http://www.ebay.co.uk/itm/OMP-FRONT-LOW ... 2c7bc668c5
If so, what/ would I need anything with it to fit it or does it use pre existing bolts?
Chris
1992 GT2
monzajake
Re: Lower Strut Brace
Post by monzajake »
Thats the one. It should come with replacement bolts
crashbanggg
Thanks!
1992 GT2
DJPremier
Post by DJPremier »
I have of of these on my Mk2. I have the anthracite version. It did not come with new bolts, but the tubular fitting points are not so thick that you need new longer bolts. Works fine with the originals. Such a worthwhile upgrade though..
Dave V
marcus
Post by marcus »
I remember Mr Funk telling me a lower strut brace transforms the handling but I neglected to ask exactly where it fits, can anyone point me in the direction of a pic or diagram?
1985 GTL 1.8
bengould
Post by bengould »
marcus wrote:I remember Mr Funk telling me a lower strut brace transforms the handling but I neglected to ask exactly where it fits, can anyone point me in the direction of a pic or diagram?
Between the front of the wishbones. Mounts using the bolt that goes through the front wishbone bush.
Ben
mr.brown
Post by mr.brown »
I've just shared a link to one on the Facebook page.
Saw that this morning. Very nice
crashbanggg
Success!
1992 GT2
Looks close to the exhaust etc from the angle of the photo?
go-for-it1
Post by go-for-it1 »
Did the wishbones move out of alignment when you took the bolts out, and did you jack one or both sides at the same time when you fitted it? Just need to know what I am up against when I fit mine.
2012 BMW 520d M Sport
2013 Golf TDi 140bhp
Member No 1241
crashbanggg
mark1gls wrote:Looks close to the exhaust etc from the angle of the photo?
I think that's just the angle of the photo, seems to be well clear of anything in reality :)
go-for-it1 wrote:Did the wishbones move out of alignment when you took the bolts out, and did you jack one or both sides at the same time when you fitted it? Just need to know what I am up against when I fit mine.
Although someone will probably come along and tell me I did it wrong, I just jacked it on one side and had no problem with the wishbones moving, simplest job I've done on the car I think!
1992 GT2
just a thought - you are *supposed* to tighten those bolts with the weight of the car on the wheels. in reality, doing that is a pain in the hole
go-for-it1
Although someone will probably come along and tell me I did it wrong, I just jacked it on one side and had no problem with the wishbones moving, simplest job I've done on the car I think![/quote]
Thanks matey.
Member No 1241
Nathan
Post by Nathan »
Thanks for the tips in this thread.
Finally got round to fitting mine this evening and boy, roundabouts sure are fun now!
