Wiring diagram for 1984 GTI? * All sorted
mr.brown
I've got some spare wires from the 14 pin instrument panel connector that I need to tidy up. The loom is from a 1984 GTI so I think the extras are either to do with the MFA (if there was one) or the upshift indicator.
I really need the whole wiring diagram so wanted to know if it was in the Haynes manual - or any other for that matter (I'm 99% sure it's not in the Bentley).
Re: Wiring diagram for 1984 GTI? Is it in the Haynes?
The diagrams in Haynes are for carburettor models up to 1984, fuel injection models up to 1984, and all models from 1985, with additional diagrams for individual circuits for optional equipment.
1985 GTL 1.8
mr.brown
Which Haynes is that? I've just found out there are at least three lol.marcus wrote:The diagrams in Haynes are for carburettor models up to 1984, fuel injection models up to 1984, and all models from 1985, with additional diagrams for individual circuits for optional equipment.
Both my Haynes have them in, they also have supplements in the back for later models.
Mine is ISBN 1 85010 513 8, copyright date is 1991, and the front says 1982-1990 and covers CL, GL, GTI, GT, GTL, GTX, GTS, Storm and Scala, 1457cc, 1588cc, 1595cc, and 1781cc. "Does not cover Scirocco GTX 16v".
1985 GTL 1.8
Same as mine, has a red cover!
Indeed.
Now out of print by the way, so hold on to it, can be hard to get hold of and prices quite volatile, about six available on Amazon currently, all affordable but a few months ago there were only two or three, for silly money.
1985 GTL 1.8
Tim_R
God, I bought mine new in halfords not long after I got my rocco, they had it on the shelf. Admittedly the car was only 11 years old back then.
Scirocco GTII 2L 16V
Mk2 Golf Gti 8v
T4 Transporter 2.4D LWB
Mk2 Golf Gti 8v
Mine came with my 'rocco, coincidentally 11 years ago, when it was already 18 years old...
1985 GTL 1.8
I've got one of the Lyndsey manuals, comes in quite handy.
What are they, not heard of them, only know 'official', Bentley, Auto???? something or other, and Haynes...
1985 GTL 1.8
Autodata. Good manuals.marcus wrote:What are they, not heard of them, only know 'official', Bentley, Auto???? something or other, and Haynes...
Ah yes, Autodata, got a stack of them in the loft along with all the Haynes (I collect them, jumble sales, charity shops... yes, I'm sad).
1985 GTL 1.8
When I took the cluster apart on my Storm to fix the coolant gauge, I was curious about the rest of the wiring to the cluster, so I made some notes using the Haynes and the Bentley. I believe this to be accurate - maybe it will be of use to you.
Scirocco Storm Instrument Cluster Wiring
(see Pages 309-311 in the Haynes VW Scirocco Manual)
Connector T7 (White connector "top row")
1 - Blue w/ White -- High Beam Warning Light
2 - White w/ Red -- Outside Air Temperature Sensor
3 - Red w/ White -- MFA mode
4 - White w/ Blue -- Outside Air Temperature Sensor
5 - Purple w/ Black -- Fuel Sender
6 - Grey w/ Blue -- Instrument Lights
7 - Blue w/ Red -- Turn Signal
Connector T7b (White connector "bottom row")
1 - White w/ Green -- Solenoid Valve for Consumption Indicator
2 - Green w/ Black -- Oil Temperature
3 - Red -- Power (Always Live "30")
4 - Red w/ Black -- Tachometer
5 - Brown -- Ground (Masse or Earth depending on your country of origin
6 - Yellow w/ Red -- Coolant Temperature Sensor
7 - Blue w/ Yellow -- Gearshift Light
Connector T7c (Black connector "top row")
4 - Blue w/ Black -- Oil Pressure .3 bar switch
7 - Black -- Power (Live w/ Coil - "15")
Connector T7a (Black connector "bottom row")
4 - Yellow -- Oil Pressure Switch Signal 1.8 bar switch
5 - Blue -- Alternator Light
Mk2 Scirocco Storm
Mk3 Golf GTI VR6
Mk3 Golf GTI VR6
mr.brown
ThomasD - that is awesome, just what I needed.
Thanks to all for the replies. I managed to find an 82-87 manual for cheap on ebay but the reply above may mean I don't have to wait for it. Roll on daylight....
