corroded springs - suspension refurb options ???
iroberts696
Got an mot advisory of 'springs showing signs of corrosion' so thinking its time to look at the, shocks, springs and bushes. dont need but would like something which corners like on rails but would prefer something which dosen't rock me to the fillings on bumps any suggsetions as to shocks, springs, bushes ? anything else ? ( tends to be about town or occasional 300 mile + mway burns ) mk 2 inj scala
Re: corroded springs - suspension refurb options ???
Lots of info on this site about whats been fitted to other peoples cars, try searching the site...
Just to get you started
http://sciroccoregisterforum.co.uk/carf ... 10&t=15712
I'm still in 2 minds about the advisory system on the mot test. I think there needs to be guidelines on what should be advised. A tyre worn to 2mm would be fair enough, but signs of corrosion on springs could mean anything. It could mean that the paint has chipped and there is some surface rust, or it could mean that they're likely to snap if you hit a decent pot hole. There are also lots of testers out there who advise on far too many things, that really aren't a problem. I suspect some of this is going to be an attempt to generate income [\drunk rant]iroberts696 wrote:Got an mot advisory of 'springs showing signs of corrosion'
- dozzum
Ive seen an advisory on an old 106 that read. "drivers door creaks"
Tim_R
Off topic.
The passenger door on my 205 creaked, one day the top hinge pin snapped when a friend got back in at a petrol station, so he spent the journey home hanging onto the handle just in case! The door was gaffa taped up for a few days while new pins were on order and passengers climbed through the window.
Regarding the springs, guess you need to take a look at them really, post some photos if you can and someone can advise better then. All you may need are some good quality new dampers, bump stops and top mounts, if you want to keep it comfortable.
Scirocco GTII 2L 16V
Mk2 Golf Gti 8v
T4 Transporter 2.4D LWB
Mk2 Golf Gti 8v
