I bought this about 4 months ago now. she was originally a GTX but the previous owner binned the DX in favour of a KR and 280mm discs. she also retrimmed the interior with some funky checkered pattern.
anywho, after a few problems with the car i started ripping things out and replacing them as i went. this is just a quick skim over whats happened in the past couple of months.
below is a picture of how she looked before i pciked her up.
work starts. wheels off, some electrics out, fuel lines and pumps replaced
all back together with her new boots.
i was having major problems with the K jet so bite the bullet and went for R1 carbs. here you can see the mani a mate made for me. we decided to balance the inlets with 10mm pipe fittings for a smooth idle and low revs. apparently this has little/no effect on performance at top end, so i have it a go. even with the jets at 150, not the expected 180 the car runs lovely. very smooth and decent power up to 5k where she looses grunt. this was to be expected with the incorrect jetting though. also, you can just see the water outlet flange, its the JMR one, and works a treat, cheers jason
carbs fitted
rocker cover sprayed and homemade oil catch tank installed
now, the carbs fouled the bonnet, so i got the grinder out.... however, this looked gash and would probably get me pulled so i bodged on a scoop for a week or two. i know, its horrible, but it had to be done.
at least i colour coded it to the car...
i then mounted the carbs a bit differently which gave me extra space and thus the scoop could be removed. just covered the hole with some aly sheet. whilst fitting the plate i got bored and sprayed the bonnet with some random paints...
...i got told off by the missus and she made me do it properly haha. now its dark brown with some chalkboard paint black stripes. looks better than my effort!
And finally, this is how she now stands as of today. somewhere near postbridge after a long drive. had to draw on the obligitory checkered patch with chalk, and some pakman stuff!
next on the cards is;
4 branch exhaust manifold
new gear linkage/bushings
new door cards
remote oil cooler
new tyres
and a respray in orange with chrome details when i can afford it!
hope you like it.
cheers
wassell
