Shock - strut seperation
Austin
Post by Austin »
Hi,
How do you separate the shock from the strut on the front suspension. I can't seem to work it out! (YES, I have removed the spring first :) )
Rich
Four Sciroccos, four gone, but at least I know all parts from most current one went to good homes....
vr_powered
Re: Shock - strut seperation
Post by vr_powered »
Undo the large nut on the top of the strut where the piston rod disapears inside, they can be a pig to undo so you may find it easier to carefully cut it with a hacksaw and split it
Village Idiots
Post by Village Idiots »
Applying heat will make it easier to undo.
go-for-it1
Post by go-for-it1 »
Hold the bottom of the strut in a decent sized vice and if the cap won't undo with a pair of stillsons, hammer it round with a drift on one of the cut outs to break the seal and then use the stillsons again. Helps to have the strut upside down for a few hours and allow some penetrating oil to run into the threads before starting to undo the cap.
2012 BMW 520d M Sport
2013 Golf TDi 140bhp
Member No 1241
