camber adjustment
camber adjustment
https://www.frost.co.uk/item_Detail.asp ... er%20Gauge
has anyone actually used the camber gauge from frosts?
vr_powered
Re: camber adjustment
Post by vr_powered »
Not yet i bought one a while ago just havent got round to it yet, i didnt like the idea of using it on the brake disc for several reasons, 1 discs can wear unevenly, 2 you would have to load the front suspension and make sure it was level so was going to make up something to be able to use it on the wheel with the car on the ground
MikeH
Post by MikeH »
^^ What he said about brake discs.
I use a straight piece of wood and a 'spirit level' app on my iPhone.
1992 Scala ABF - SOLD
1989 Scala track toy. Dormant
1.6GL. 2 Owners, 60k. SOLD
resurrecting an old thread ive just found this
http://www.instructables.com/id/Hands-f ... ber-Gauge/
steve bain
Post by steve bain »
I used a length of wood with a screw sticking out 6mm at top, rested against the wheel with a plumb Bob (cotton with screw on the end). The 6mm is about 1degree of camber.
Checked it on the ground. Measured how off it was, took wheel off, dialled back in the offness from the disc. Refitted wheel and checked. Seemed to work.
Just have to do tracking now.
My build thread:
viewtopic.php?f=19&t=14083
