Page 1 of 2
Brembo pads..
Posted: Sun Mar 13, 2011 11:20 am
by Beddo88
Hi all, anyone have any experience with these? I presume they must be reasonably decent being brembo, just thought i'd enquire.
Picked some up from gsf for just £15, they're a bit strange, (to me) in that they have two different pads for each side. I've matched them so that the same pad is on each side of the discs, ie. same pad on piston side / slave side. One of them has a very logn thin design, sits right at the edge fo the disc so presumably should give improved braking. :) Just wearing them in atm... forgot how fun that is!
Re: Brembo pads..
Posted: Sun Mar 13, 2011 10:05 pm
by richlyons
dont all vw sciorcco front pads differ from in side to outside?
Re: Brembo pads..
Posted: Sun Mar 13, 2011 10:13 pm
by Beddo88
Dunno.. the previous ones i had on it were the same both sides. Unless the ones i had previously were some really rubbish ones?
Re: Brembo pads..
Posted: Sun Mar 13, 2011 10:32 pm
by go-for-it1
So are you saying you have fitted them with 2 pads the same shape on one wheel, and the 2 with the other shape on the other wheel? If so that is the wrong way. There should be 1 of each pad on each wheel with the long narrow one fitted on the slave (non piston) side.
Re: Brembo pads..
Posted: Sun Mar 13, 2011 11:12 pm
by GTXTRA
moved to right section.
Re: Brembo pads..
Posted: Sun Mar 13, 2011 11:25 pm
by Funky Diver
go-for-it1 wrote:So are you saying you have fitted them with 2 pads the same shape on one wheel, and the 2 with the other shape on the other wheel? If so that is the wrong way. There should be 1 of each pad on each wheel with the long narrow one fitted on the slave (non piston) side.
I think (from what he's put) that he's used matching pads inboard of the discs, and the other set of matching pads roadside on the disc...
Re: Brembo pads..
Posted: Mon Mar 14, 2011 4:54 pm
if they are fast road pads or similar, make sure you bed them in gently
Re: Brembo pads..
Posted: Mon Mar 14, 2011 8:04 pm
by Beddo88
There is one of each pad on each disc. And yes, i've fitted the long narrow ones to the slave side. So guess i got it right!! There was not a single helpful bit of advice with the pads. Except maybe dont eat them.
Not sure what spec they are, brembo pads weren't listed on gsf's website, i just got offered them at the till, thought i'd give them a shot!
Opinions on best way to bed the pads in? Just slow and gentle? And how do i tell when they are bedded in properly?
Re: Brembo pads..
Posted: Mon Mar 14, 2011 11:53 pm
by richlyons
nice and easy with them form about 100miles will bed them in ok.
though i would think brembo come pre beded in?
Re: Brembo pads..
Posted: Tue Mar 15, 2011 6:28 am
richlyons wrote:nice and easy with them form about 100miles will bed them in ok.
correct :)
can't work this one out. how could they be pre-bedded in to your discs? :scratch:
Re: Brembo pads..
Posted: Tue Mar 15, 2011 10:59 am
by richlyons
Some pads come pre bedded in don't they?
Re: Brembo pads..
Posted: Tue Mar 15, 2011 3:41 pm
by Funky Diver
I think they're more that thery dopn't have the daft glaze on them. They'll still need "shaping" to the existing discs, minor grooves and wotnot persisting.
Re: Brembo pads..
Posted: Tue Mar 15, 2011 6:18 pm
by Beddo88
Fitted new discs at the time, so it'd be irrelevant either way :P The swirls from the discs machining are starting to go now... so they're getting there slowly!
Re: Brembo pads..
Posted: Wed Mar 16, 2011 7:59 am
even with a new discs, the pads will still want bedding in properly. if you don't there is a good chance of warping the disc. i've got no idea of the physics behind it, but i have done it twice - once on the rocco and once on one of my astras
Re: Brembo pads..
Posted: Wed Mar 16, 2011 6:05 pm
by Beddo88
Good thing i've not been driving like a bat out of hell then :) But with these prices.. im not sure much will change after!
