Brembo pads..
Brembo pads..
Hi all, anyone have any experience with these? I presume they must be reasonably decent being brembo, just thought i'd enquire.
Picked some up from gsf for just £15, they're a bit strange, (to me) in that they have two different pads for each side. I've matched them so that the same pad is on each side of the discs, ie. same pad on piston side / slave side. One of them has a very logn thin design, sits right at the edge fo the disc so presumably should give improved braking. :) Just wearing them in atm... forgot how fun that is!
Re: Brembo pads..
dont all vw sciorcco front pads differ from in side to outside?
1988 helios blue scala, weber carb, gti cam,
1989 red gt2 (daily)
Re: Brembo pads..
Dunno.. the previous ones i had on it were the same both sides. Unless the ones i had previously were some really rubbish ones?
- go-for-it1
Re: Brembo pads..
So are you saying you have fitted them with 2 pads the same shape on one wheel, and the 2 with the other shape on the other wheel? If so that is the wrong way. There should be 1 of each pad on each wheel with the long narrow one fitted on the slave (non piston) side.
2012 BMW 520d M Sport
2013 Golf TDi 140bhp
Member No 1241
- Funky Diver
Re: Brembo pads..
I think (from what he's put) that he's used matching pads inboard of the discs, and the other set of matching pads roadside on the disc...go-for-it1 wrote:So are you saying you have fitted them with 2 pads the same shape on one wheel, and the 2 with the other shape on the other wheel? If so that is the wrong way. There should be 1 of each pad on each wheel with the long narrow one fitted on the slave (non piston) side.
Re: Brembo pads..
There is one of each pad on each disc. And yes, i've fitted the long narrow ones to the slave side. So guess i got it right!! There was not a single helpful bit of advice with the pads. Except maybe dont eat them.
Not sure what spec they are, brembo pads weren't listed on gsf's website, i just got offered them at the till, thought i'd give them a shot!
Opinions on best way to bed the pads in? Just slow and gentle? And how do i tell when they are bedded in properly?
Re: Brembo pads..
nice and easy with them form about 100miles will bed them in ok.
though i would think brembo come pre beded in?
Re: Brembo pads..
correct :)richlyons wrote:nice and easy with them form about 100miles will bed them in ok.
can't work this one out. how could they be pre-bedded in to your discs?though i would think brembo come pre beded in?
Re: Brembo pads..
Some pads come pre bedded in don't they?
- Funky Diver
Re: Brembo pads..
I think they're more that thery dopn't have the daft glaze on them. They'll still need "shaping" to the existing discs, minor grooves and wotnot persisting.
Re: Brembo pads..
Fitted new discs at the time, so it'd be irrelevant either way
The swirls from the discs machining are starting to go now... so they're getting there slowly!
Re: Brembo pads..
even with a new discs, the pads will still want bedding in properly. if you don't there is a good chance of warping the disc. i've got no idea of the physics behind it, but i have done it twice - once on the rocco and once on one of my astras
Re: Brembo pads..
Good thing i've not been driving like a bat out of hell then :) But with these prices.. im not sure much will change after!
