Weird starting/running
Posted: Sat Jan 29, 2011 1:01 pm
by cranwellpoacher
I had the engine tuned the other day and hoped that this would resolve a problem that I have been experiencing when starting the car. It strikes up first time but then, if you touch the accelerator the engine looses power and stalls. Also, the engine ignition feels and sounds a bit weird. Almost like a missfire. If you imagine the sensation of a normal cycle of ignition you can sort of sense the cylinders ignition sequence and the engine feels balanced. My Scala's engine feels unbalanced and (in an attempt to to describe it!) instead of a smooth cycle it feels like the ignition process is causing too many sparks! sort of a brrrrrrrrrr rather than a bang,bang,bang...does this make any sense?
Car is EX engine, Peiereburg 2E2 Carb and standard fuel/ignition.
Cheers.Andy
Re: Weird starting/running
Posted: Sat Jan 29, 2011 1:03 pm
by Jay4424
all your spark leads are on and got good conections right?
all the vac pipes are on and in good condition right?
the cold starting valve is working?
err, compression on all cylinders is correct?
Jay.
Posted: Sat Jan 29, 2011 4:55 pm
by ianaudia4
I would be inclined to go back to the place who "tuned" it, was it a general garage or a VW specialist?
Posted: Sat Jan 29, 2011 11:49 pm
by scirsteve
Probably bit of long shot but, something kinda similiar I experienced to that was ignition timing related.
Sorry, thats about as near as I can get.
Good luck.
Posted: Sun Feb 06, 2011 10:09 pm
by Neillyboy
Any chance the tuners were leaning in the airbox and split the flange between the carb & manifold?
Posted: Mon Feb 07, 2011 1:51 pm
by MikeH
^^ What he said. Sounds like an air leak to me. Check the vac connections - maybe they set the timing and forgot to reconnect the vac hose to the dizzy?
