Replacing Rocker gasket
Hi all, finally had enough of having an engine slowly being covered in oil, so gunna sort out the rocker cover. Any advice on which way to loosen/tighten the bolts that it in place? Is there an ideal order like there is with the head? or just a kind of 'dont undo one end then the other'.
Dan
Dan
- Funky Diver
- Jay4424
Re: Replacing Rocker gasket
unless like me something goes massivly wrong (dont know how, dont it on several cars) and the thing goes up in flames
'52 BSA A10
'37 72' wooden narrow boat
'03 Suzuki GSX1400
'52 BSA A10
'03 Suzuki GSX1400
Get the rocker cover gasket from the dealer and it will be the rubber MK3 Golf type, 1 piece and a new stud kit, much better and only £15.
I was taught to start in the middle and work you way out when tightening, as like you say doing a head.
You will find the part number on here somewhere if you do a search.ianaudia4 wrote:Get the rocker cover gasket from the dealer and it will be the rubber MK3 Golf type, 1 piece and a new stud kit, much better and only £15.
cranwellpoacher
Rocker cover gaskett and 2x seals kit cost me £2.79
Engine is so much more oil free and I don't get a whiff of oil fumes when sat in traffic!
- Jay4424
it should be a calke one... shouldn't it?
'52 BSA A10
'03 Suzuki GSX1400
'52 BSA A10
'03 Suzuki GSX1400
They did have cork ones back in the day but if you go into a dealer and ask for a rocker cover gasket for a Scirocco this is what they will sell you, much better and will last years.
Oh.. well i bought a replacement er.. some months ago from GSF. Its the Cork type with the seperate cam seal. Dont imagine it should be a dificult job, ended up busy today so its been mvoed to tmoz. Been playing with another part today... mini weekend project :)
thebrief_1979
If you use the rubber gasket you have to change the bolts as the original bolts have a shoulder on them which means steel insert on the rubber gasket gets in the way and stops it all sealing up properly. I have 1 rubber gasket - new - if you want it for a few quid
1993 MK2 Flash Red GT2 - sold
Mk1 gls - nearly
Mk1 gls - nearly
Cheers for the offer dude, but if i've gotta get bolts for it as well it doesnt seem worth the hassle. No suppliers near me lol
Should be a fun car filled day tommorrow :) Can't wait for summer, or spring actually!!
Austin
Just don't make the mistake I did, don't go to GSF - they'll tell you it's a straight swap, it's not!! - you need longer studs with the rubber ones. Careful not to overtighten the nuts.
Four Sciroccos, four gone, but at least I know all parts from most current one went to good homes....
