I want to get some decent bulbs but really have no idea what is good value for money. The current bulbs are all weather ones - Yellow in colour and useless. Ideally want them to be as clear white as possible but you can spend anything from a couple of pounds to £75 for a pair of Piaa ones.
would probably consider a kit to uprate them if necessary but not a HID kit.
advice please - thanks
Bulbs
thebrief_1979
thebrief_1979
Re: Bulbs
cheers Ryan - i will have a look on Marks car - see how they look
1993 MK2 Flash Red GT2 - sold
Mk1 gls - nearly
Mk1 gls - nearly
Re: Bulbs
Same as Ryan, spot on a brighter than some "cheapies"! I got mine from ECP for about £20 a pair.
- Ryan
Re: Bulbs
Doh!PeteGLi wrote:Also, if you have not yet relayed the headlight loom, do so.
Yep I'd go with this first - as you may find the bulbs will be fine thereafter - however you may still want to relay the bulbs if you swap them first...
