Deleting rear speaker/parcel shelf supports.Best way ?
MrD
Post by MrD »
Been wanting to get rid of the 2 metal supports from the back of my roc,but not sure which is the best way to do it ,without doing any damage to surrounding areas.
On drivers side it`s sandwiched between inner arch,pass side it`s on top.Spot welded all the way around.
A) Drill out spot welds,will the make the rest weaker ?
B)Angle grind along the bottom ,as close as i can get,prob with this will be how it looks after :blush:
C)Hacksaw and a hammer and cold chisel.
Opinions,anyone else done this /
filmidget
Re: Deleting rear speaker/parcel shelf supports.Best way ?
Post by filmidget »
I haven't looked properly, but I had it in my head just to attack with the angle grinder, maybe tidy up with a Dremel
Big Bad Baz
Post by Big Bad Baz »
It begs the question - why?
F668VBD - Gone, but not forgotten.
MrD
Post by MrD »
As the rear interior is stripped out,ally fuel tank,and all my fuel pumps etc are in the back,so won`t be using a parcel shelf,just think they look untidy,and are surplus weight,
Having loads of probs with photobucket,cant see any of my pics,weird ?
skattrd
Post by skattrd »
This is on my list of things to do on white, personally I was planning on just grinding them off.
The back of mine is going to be carpeted though, so I wasn't too bothered if it was a bit untidy.
roccodave
Post by roccodave »
you can get a special drill for spotwelds do it with one of those and it should be quite neat after :hugegrin:
MrD
Post by MrD »
Smashing,that`s what i wanted to hear ! Think there might also be an attachment for a welder,to de spot weld,not sure if it would work on my mig,or an arc welder though ?
Just found this !
http://classicsagogo.co.uk/acatalog/Special_Tools.html
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 0332145041
i'd just go thru the spots with one of these (or a normal drill) then either fill the holes with mig, or seam weld the joint back together. however you go about it, it's gonna need paint afterwards
MrD
Post by MrD »
Well i spent a few hours today ,removing the shelf supports :hugegrin: Combination of hacksaw,drill,angle grinder (scary as tank right next to where i was cutting) i found it easier to free up both ends first,then most of the spot welds gave way with a wobble,and smack from cold chisel,didn`t do too much damage either which was also a bonus.
Have give it a thin smear of filler,but will build up a few thin layers,so it looks nice and smothe..
Friendly passenger :hugegrin: Image
MrD
Post by MrD »
Got a bit more done today
Moved extinguisher,so it`s within reach,moved amp so i could put extinguisher where amp was.
Bolted sub to rear pass seat space,drilled through and screwed up from underneath,nice and firm now.
Gotta save a few more kg`s :hugegrin:
Niall
Post by Niall »
One can only assume this is a track day car?
Bit confused as to why you've put great big 600W sub in the back? You could save a lot more weight just running some powerful speakers through an amplifier and wiring that through the car. Those boxes are heavy. Also as a matter of personal choice i'd have gone with Vibe for the quality.
MrD
Post by MrD »
Road / Track ,once it get it finnished it will see the occasional day out on the track.
The sub and stereo etc were a crimbo pressie about 3 years ago ,so musn`t grumble about the quality,plenty loud nd clear enough,although i have my eye on a Johna lomu amp ,and a much more powerfull sub ,will be getting some sort of brackets made up for fast removal,once i work my way through the rest of the list,currently 2 sides of a4 :blush: ..
Got Jbl door speakers,Kole tweeters running of the amp in the front,sub has another amp in the back
that luks really gud m8 with them shelves taken out, opens it up that little bit more. :good:
MrD
Post by MrD »
Yes looks much more spacious in the back now
Just needs finishing off,when i get time
Slugga
Post by Slugga »
Great pics :)
Is your fuel tank a custom jobby or an off-the-shelf part? I frickin' love it!
