This problem relates to a 1043cc mk.2 Polo (manual choke).
I was heading along the M5 the other day and noticed the car wasn't pulling as well as it should do, then eventually it lost all power so I pulled onto the hard shoulder. Noticed some smoke coming from under the bonnet, so had a look and the only thing I could see was a lot of oil behind the air box, and a big split in one of the ventilation pipes from the cylinder block in this area. Numbered "1" in the picture:
The only problem I've had with the car up to this point has been a dodgy idle (not sure if related in any way).
Anyway, I restarted the car and it ran and pulled away ok, so I continued steadily on my journey. A few miles further up the road, the oil pressure warning light and buzzer came on, so I drove gently to the nearest garage, established that there was no oil in the engine and filled it up.
My questions are: is the oil likely to be coming out of the split hose? Would that be a bad thing?
