Looking at buying some...will I need to run spacers or do any arch work?
They are 15x7 and I am running coilovers, quite low. Not sure which of the two offsets they are, but will one be better than the other?
ATS Cups
Re: ATS Cups
check with Bill - his mint red gtx runs 7 x 15 cups on 45 series rubber.
you should be fine with the et28's but et20 may require arch work at rear.
