hi,
Im getting a kr soon to put in my rocco, the only thing im not sure about is ive herd the dizzy fouls the mc? Does it and if so what do people do?
MAny thanks rich
kr in a rocco
Re: kr in a rocco
forgot to say the enging is out of a corrado with kjet
1988 helios blue scala, weber carb, gti cam,
1989 red gt2 (daily)
Re: kr in a rocco
The standard KR dizzy will foul the standard scirocco brake fliud reservoir. The easiest solution is to get an ABF dizzy cap (the leads come off it at 90 degrees rather than straight) and it will then miss the fluid reservoir
![Image](http://i240.photobucket.com/albums/ff204/Birdyvw/DubMania2.jpg)
Re: kr in a rocco
could you just use the leads? Or do you have to use the cap to?
Re: kr in a rocco
IIrc Just the cap, leads will be the same!richlyons wrote:could you just use the leads? Or do you have to use the cap to?
![Image](http://i168.photobucket.com/albums/u191/richieAmusic/IMG_1576-1.jpg)
weber'd valver :D
Re: kr in a rocco
cool, thanks for that,.
Does anyone know what size drive shafts a o2j box uses? Are they 100mm?
Ive got 90s in atm.
Ive got 90s in atm.
Re: kr in a rocco
thinking about it, could i use new 100mm (or what size they are) cv joints on my 90 drive shafts?
I just thought i may as well renew the boots when ther off so why not the full joint?![vcool :vcool:](./images/smilies/cool.gif)
