Starter motor help/advise
sciroccosi
Post by sciroccosi »
Hi chaps ive just completed a 2 litre AGG conversion in my 1991 mk2 gti,i know its not a scirocco but the same is often used in them, ive used the modded PB head and the AGG bottom end, (new big end shells etc) it runs like a dream but it seems slow when starting up for the first few times, ive changed the battery and still the same, im not sure if i read somewere that this is a comon problem and to use a diesel starter motor instead, can anyone help me out here as to which one etc or other advice cheers simon
Chaps
Re: Starter motor help/advise
Post by Chaps »
Have you got a multimeter? if so, first place to check would be the earthing continuity from the starter case to the battery - terminal. make sure the earth strap in good condition too as this can effect starting.
And also, is your battery fully charged? This cold spot might have taken its tole on the battery?
sciroccosi
hi mate yeh done all the usual checks an the battery is a newish varta one and i have also tried the battery off my scirocco that i know is good an fully charged so i just think the starter is tired to be honest
Chaps
Post by Chaps »
Possibly... there is a VW breaker just off the M65 going towards Chorley who'll sort you out one fairly cheap if your looking to replace it. Dub Haus VWs its called, i can get you the details if you need. I got some bits from him the other day he's got loads of bits n bobs down there.
MikeH
Post by MikeH »
The Mk3 Golf 8v GTI Starter has a reduction gear which will help cranking on the 2.0 engine, which is longer stroke and slightly higher compression. It's a more commonly available option, compared to the diesel starter, as most of the diesels don't use an 020 gearbox.
1992 Scala ABF - SOLD
1989 Scala track toy. Dormant
1.6GL. 2 Owners, 60k. SOLD
sciroccosi
Hi mate yeh i know lyndon ive known him for years, as for the diesel starter ive been rooting on my local scrapyard and the polo saloon 1.9sdi starter looks like it'll do the job, im sure i read somwere that the mk3 starter wont fit as its a cablechange box but i could be wrong lol
