Its just that way with cars, no sooner youhave one thing fixed something else breaks...And its bloody freezing outside!
(MK2 Scala 1.8 Carb, 95k miles).
Recently changed the rocker cover and gasket as I couldn't stop it leaking...
And now the oil buzzer and warning light came on today, it's never happened before!
-I followed the faq guide on here to test both oil sensors, they behave the way they are supposed to.
It looks like its the high pressure sensor triggers the buzzer and light, and low pressure one triggers just the warning light.
So from this I was getting the idea its too high pressure?
-I bought an oil pressure gauge from halfrauds today, and fitted that to the hole where the low pressure sensor goes.
It showed around 15-20 psi? at idle, but when revs are raised it went all the way up and up to around 80 - 100psi!
-I've seen people suggest on here the oil pump / pressure relief valve which I understand are combined together in the sump. Is it possible to replace just the one, if so wheres best to get one? How difficult is it to do this, bearing in mind I actually need to replace the sump anyways as its rusted?
Anything else worth trying? Appreciate any advice.
Cheers,
Chris
