Caliper bolts
Posted: Fri Nov 05, 2010 10:37 pm
by andyneedham2
I had a bit of a worrying moment today. My drivers side caliper bolt (bottom) had come loose and was about to fall out. I'd been hearing a knocking sound which I thought was a ball joint but as I was driving the sound seemed to get worse so I pulled over as I didn't think the sound was solid enough to be a ball joint, thats when I found out it was the caliper bolt was loose. Any suggestions for getting the bolts in and keeping them there?! It crapped me up!
Re: Caliper bolts
Posted: Fri Nov 05, 2010 10:39 pm
by Risocco
Personally dude I would resist the temptation of gluing the threads as these are buggers for rounding off. Just re-tighten them dude, they should be tightened on pretty darn hard
Alex
Re: Caliper bolts
Posted: Fri Nov 05, 2010 10:51 pm
by andyneedham2
Yeh, I noticed the previous owner had hammered a star key in there which is now pretty rounded off, might have to track some new ones down. i think GSF will prob still stock them...
cheers for the advice pal.
Re: Caliper bolts
Posted: Fri Nov 05, 2010 10:57 pm
by Risocco
Slightly off topic but am I right in saying that hex bolts were invented as they were thought to be impossible to round off? Somebody told me that recently. They evidently have no experience of VWs
Failing GSF, the dealers will have them dude
Alex
Re: Caliper bolts
Posted: Fri Nov 05, 2010 11:05 pm
by andyneedham2
people seem to think hex bolts were invented for smashing into rounded allen nuts! Ah well, I'll have a ring around. thanks for the advice
Re: Caliper bolts
Posted: Sat Nov 06, 2010 9:06 am
by steve
If it's the slide bolts, get em renewed. They're pennies from VW and you can get a reuild kit to replace the rubbers along with the brass bushes for a few quid a side while you're there.
Re: Caliper bolts
Posted: Sat Nov 06, 2010 10:38 am
by andyneedham2
This seems to be a good idea, thanks. Can't skimp on the brakes!
Re: Caliper bolts
Posted: Sat Nov 06, 2010 1:23 pm
by PeteGLi
steve wrote:....... the brass bushes ........
What brass bushes??
Have a look here
http://sciroccoregisterforum.co.uk/faq/ ... ch/brakes/ for the differences in the VWII calipers
Re: Caliper bolts
Posted: Wed Nov 17, 2010 10:05 pm
by rocco1982
I had a big problem with this, even after replacing the bad bolt for a brand new one. It turned out the thread on the caliper carrier was knackered, so I had to put a replacement carrier on to get the bolt to tighten properly.
Re: Caliper bolts
Posted: Sat Nov 20, 2010 12:20 am
by andyneedham2
Well, to be fair, thats probably not a bad idea.... Good time for a brake upgrade!!
