Caliper bolts
andyneedham2
Caliper bolts
Post by andyneedham2 »
I had a bit of a worrying moment today. My drivers side caliper bolt (bottom) had come loose and was about to fall out. I'd been hearing a knocking sound which I thought was a ball joint but as I was driving the sound seemed to get worse so I pulled over as I didn't think the sound was solid enough to be a ball joint, thats when I found out it was the caliper bolt was loose. Any suggestions for getting the bolts in and keeping them there?! It crapped me up!
Risocco
Re: Caliper bolts
Post by Risocco »
Personally dude I would resist the temptation of gluing the threads as these are buggers for rounding off. Just re-tighten them dude, they should be tightened on pretty darn hard :good:
Alex
andyneedham2
Re: Caliper bolts
Yeh, I noticed the previous owner had hammered a star key in there which is now pretty rounded off, might have to track some new ones down. i think GSF will prob still stock them...
cheers for the advice pal. :buddy:
Risocco
Re: Caliper bolts
Post by Risocco »
Slightly off topic but am I right in saying that hex bolts were invented as they were thought to be impossible to round off? Somebody told me that recently. They evidently have no experience of VWs :ire: :hehe:
Failing GSF, the dealers will have them dude :good:
Alex
andyneedham2
Re: Caliper bolts
people seem to think hex bolts were invented for smashing into rounded allen nuts! Ah well, I'll have a ring around. thanks for the advice
steve
Re: Caliper bolts
Post by steve »
If it's the slide bolts, get em renewed. They're pennies from VW and you can get a reuild kit to replace the rubbers along with the brass bushes for a few quid a side while you're there.
andyneedham2
Re: Caliper bolts
This seems to be a good idea, thanks. Can't skimp on the brakes!
PeteGLi
Re: Caliper bolts
Post by PeteGLi »
steve wrote:....... the brass bushes ........
What brass bushes??
Have a look here http://sciroccoregisterforum.co.uk/faq/ ... ch/brakes/ for the differences in the VWII calipers
rocco1982
Re: Caliper bolts
Post by rocco1982 »
I had a big problem with this, even after replacing the bad bolt for a brand new one. It turned out the thread on the caliper carrier was knackered, so I had to put a replacement carrier on to get the bolt to tighten properly.
Ex-owner of a 1990 1.8 GTII
1982 Mk1 Golf (daily driver)
andyneedham2
Re: Caliper bolts
Well, to be fair, thats probably not a bad idea.... Good time for a brake upgrade!!
