Oil Leak cant source
jonkennedy
i have a leak on the back left hand side of the engine.
it seems to be dripping in this area ( see pictures )
im not sure of fixing it myself unless its very easy but if you could give me an idea of what to expect from my garage
before they rip the rear from my bank account
the problem has only occurred since i put some high grade / performance oil in whilst on a journey.
i fear it may have unclogged some holes that would have been better filled with dirt !
thanks in advance
jon
thanks in advance
jon
bensspares
Re: Oil Leak cant source
its the rocker cover gasket leaking ...... easy,check haynes, for a cork gasket aprox £3 not sure on the rubber ones but the easy route is the cork one.gararge could charge you upto £50 for this....take you about halfhour following mr haynes.
jonkennedy
nice one ben !bensspares wrote:its the rocker cover gasket leaking ...... easy,check haynes, for a cork gasket aprox £3 not sure on the rubber ones but the easy route is the cork one.gararge could charge you upto £50 for this....take you about halfhour following mr haynes.
the rocker cover is the black metal housing right ?
( sorry im a total novice but willing to get oily )
jonkennedy
i can only see a CARB one on ECP.. will that fit my INJECTION ?bensspares wrote:its the rocker cover gasket leaking ...... easy,check haynes, for a cork gasket aprox £3 not sure on the rubber ones but the easy route is the cork one.gararge could charge you upto £50 for this....take you about halfhour following mr haynes.
http://www.eurocarparts.com/search/rock ... /Car-Parts
bensspares
black thing = rockercover.
part nunber 368440020.......£3.06.
mr haynes covers this section well...
ben
ben
jonkennedy
thanks man !bensspares wrote:black thing = rockercover.
ben
Get a rubber one from the dealers, cost approx 15 quid but comes complete with new studs. much better as one piece!
jonkennedy
does a CARB one fit INJECTION rocker ?ianaudia4 wrote:Get a rubber one from the dealers, cost approx 15 quid but comes complete with new studs. much better as one piece!
I went to a VW dealer and gave them my engine code (DX) and I was given one that fitted!
jonkennedy
enginecode is located in the boot somewhere ?ianaudia4 wrote:I went to a VW dealer and gave them my engine code (DX) and I was given one that fitted!
If your car is an 1.8 8v injection, it will be a DX engine. The engine code will be on your V5 as well.
GT Matt
Looking at where the leak is coming from, would also be worthwhile checking the front camshaft oil seal.
GT Matt
1988 Mk2 GTX
1988 Mk2 GTX
jonkennedy
is that difficult to change ?GT Matt wrote:Looking at where the leak is coming from, would also be worthwhile checking the front camshaft oil seal.
and is it worth giving the underside a jet blast to clean it up a bit ?
common problem on older engines. they are not designed for thin synthetic oil. it is easier for it to escape thru very small "gaps" that a thicker oil won't. 10w40 or 15w40 or even 20w50 in a megamilerjonkennedy wrote:the problem has only occurred since i put some high grade / performance oil in whilst on a journey.
jonkennedy
thats what i thought as i was pouring it in. but i had no choice since i was a lil low and its all they had ..Nate wrote:common problem on older engines. they are not designed for thin synthetic oil. it is easier for it to escape thru very small "gaps" that a thicker oil won't. 10w40 or 15w40 or even 20w50 in a megamilerjonkennedy wrote:the problem has only occurred since i put some high grade / performance oil in whilst on a journey.
