Alternator / Drive Belt
jonkennedy
Post by jonkennedy »
im about to change it..
It's easy enough if i follow the Haynes ?
jonkennedy
Re: Alternator / Drive Belt
Easy as, just loosen the adjuster, take off old belt and replace, then retighten!
bensspares
Post by bensspares »
yes realy easy.a 13mm spanner/socket wrench and a 6mm alan key.
jonkennedy
thanks chaps...
it says i have to run it in a bit too ?
ie re tighten after 880 miles( ish )
bensspares
true, you should check all recently fitted belts for security and tension.
porkymcchop
Post by porkymcchop »
I can confirm, its super easy. Shame i killed my clutch shortly afterwords. Less easy. Gah
