Steering Racks - Scirocco V Mk1 Golf
- scalainj
tGuys
Is their any difference at all in terms of ratio, lock, internals that anyone knows off?
My rack is failing and i have the choice of a GSF or similar for £85 or a Quafe quick rack with 2.9 lock for £140 ish.
Spoke to quaife yesterday and they require a Mk1 rack for this conversion so before i toddle up there later and do the deal i just want to make sure that the internals will fit into a Scirocco rack
Andy
Andy
91 Scala
05 Alfa 156 Ti
06 Alfa GT
05 Alfa 156 Ti
06 Alfa GT
Village Idiots
Re: Steering Racks - Scirocco V Mk1 Golf
Same part number on ETKA, so yes
- Ryan
I was looking at the Quaife rack too.
But not since fitting the smaller steering wheel = Job done
- scalainj
Well i went and bought one anyway
Now all i need is a rack bushing kit! Any ideas anyone
and i have a smaller steering wheel - should make it heavy
91 Scala
05 Alfa 156 Ti
06 Alfa GT
05 Alfa 156 Ti
06 Alfa GT
Powerflex, Bugpack or if you want solid mounts, have a search on ClubGTi as I think they had one of the tuning firms make some up and retail them.
- scalainj
My mistake - i mean't for inside the rack - perhaps i should have said seals rather than bushes
Andy
Andy
91 Scala
05 Alfa 156 Ti
06 Alfa GT
05 Alfa 156 Ti
06 Alfa GT
Ok.
However I don't think there are any seals or bushes inside. I cannot see any in the exploded drawing in the workshop manual, but have a look on ETKA, just to be sure.
- scalainj
Thanks Pete
I don't have Ekta, well i do but this new machine won't run it
Rack will be off today and in bits so i know exactly whats inside. Never done a rack but the man from Quaife tells me i need bushes/seals.
Appreciate your help. I have that workshop exploded Scirocco guide but its miles away (useful eh)
Andy
Andy
91 Scala
05 Alfa 156 Ti
06 Alfa GT
05 Alfa 156 Ti
06 Alfa GT
- scalainj
Thie remains in a 1000 pieces - bloody pinion bearing
One day i'll get to drive the thing
91 Scala
05 Alfa 156 Ti
06 Alfa GT
05 Alfa 156 Ti
06 Alfa GT
- scalainj
Still not done - all down to the pinion bearing
20*35*7 is the one in my rack, 20*32*7 is the one quaife supply which doesn't fit the housing. Spoken to them of course but they assure me theres is the right size. Evey rack i've seen now and i've seen many (from all kinds of Mk1 chassis (they are all the same)) has the 20*35*7 size. Of course 20*32*7 is comercially available but the the 35mm is not.
This comes down to Quaife being lazy in their measurements and knowledge and they are plain not interested. Bear that in mind if you are buying quaife goods that customer service comes under - None whatsover because we know best even though they admitted that they are Ford guys and don't really know VWs
I might do a how to on this - just in case anyone else ever fancies it so you can avoid the time and effort i've spent scraching my head
However i am more than happy to be corrected if anyone has a rack with a 32mm pinion bearing and housing. Its possible the dimensions were changed of just that one piece and nothing else by 3mm of course.
Andy
Andy
91 Scala
05 Alfa 156 Ti
06 Alfa GT
05 Alfa 156 Ti
06 Alfa GT
- Brunty
Thread resurrection!
I fitted the quaife kit in one of my racks for the racing car. Went in fine and works brilliantly. I got it with the Club GTI group buy years ago when they started the production of it.
I have it with a tiny steering wheel and 195 Toyo R888, it's VERY heavy.
Brunty
Tim_R
Seems that it could be a problem with aftermarket racks. I haven't read the entire thread though so don't know the outcome.
http://www.clubgti.com/forum/showthread.php?t=107035
Edit cos its an old thread but may be of use to someone.
Scirocco GTII 2L 16V
Mk2 Golf Gti 8v
T4 Transporter 2.4D LWB
Mk2 Golf Gti 8v
- scalainj
Interesting to see that Quaife knew about this problem back in 2007
First and last time i'll get anything from them. Also nothing to do with aftermarket racks - my rack casing is original and it would appear that the pinion bearing housing can be either 32mm which i've never seen or 35mm - which i have seen a load of
Anyway Kent Bearings cameto my rescue by souring the correct bearing in Holland. Its been fitted for a while and its great and i highly recommend - getting someone else to fit it
Andy
Andy
91 Scala
05 Alfa 156 Ti
06 Alfa GT
05 Alfa 156 Ti
06 Alfa GT
